Flat Sequence Structure
Is there some way to get 'Add Frame' vertically (downwards) in flat sequence structures?
Message 1 of 20
(2,992 Views)
Hi Jyo,
No.
The better question is: Why do you think you need more than a "one frame sequence structure"?
What exactly do you want to solve where THINK DATAFLOW doesn't seem to apply?
Message 2 of 20
(2,988 Views)
@GerdW wrote
No.
Yes!
In Windows: ALT+CTRL+ Right Arrow 😁
Message 3 of 20
(2,942 Views)
Hi Wiebe,
On my computer (at work) nothing happens for this specific key combination, but I guess what you are talking about… 😄
Message 4 of 20
(2,936 Views)
@GerdW wrote:
Hi Wiebe,
Hotkeys can be disabled (somewhere, the location changes all the time).
CTRL+ALT+Arrow sure freaked me out the first time I hit it accidentally.
Message 5 of 20
(2,930 Views)
Unless you are doing pretty sophisticated "time" measurements (particularly on a Real-Time platform) or programming FPGA, you should (almost) never use a Sequence structure.  Use Wires (such as the Error Line) to establish the sequence of operations.
Bob Schor
Message 6 of 20
(2,902 Views)
The answer is: You can only add frames to the right and left in flat sequence structures.
While it is generally true that you don't often need multi-frame flat sequence structures, they can be useful for structuring code visually, and forcing execution order when using LV primitives without error in/out terminals.
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 7 of 20
(2,863 Views)
And please (please!) don't vote for this idea.
Message 8 of 20
(2,848 Views)
FPGA aside, you could get away with zero sequence structures if you make a subVI out of the code you want to encapsulate.
Bill
CLD
(Mid-Level minion.)
Message 9 of 20
(2,844 Views)
Hmmm... Compared to natural languages, for example, egyptian hieroglyphs could be written vertically, (and, by the way, right to left as well). So, we can turn code into kind of art work:
And also traditionally, Chinese, Vietnamese, Korean, and Japanese are written vertically in columns...
Message 10 of 20
(2,829 Views)
