Flat sequence and stacked sequence
From a Numeric Constant to the Structures, all (most of ?) the functions and VIs of the LabVIEW library have the Description and Tip... property. The description field could also be an interesting place to put comments.
Here we come to something I'm missing/expecting for years.
Unfortunately, unless you use some technique to point out the documented elements of a diagram, there will be no way to be remembered of these comments when opening the VI. Right-clicking on every element of the diagram to open its description dialog box when looking for possible comments is definitely not acceptable !
Therefore, I would like to suggest NI to change the appearance of a function/VI when a description has been written. More, it would be useful if the description was displayed in some way when the mouse is over the element.
What do you think about this ? Do you use the description field ?
Message Edité par JB le 07-15-2008 12:05 PM
Message 31 of 52
(1,982 Views)
I think it is a grt suggestion.Will def be very helpful
Message 32 of 52
(1,979 Views)
The context help window (ctrl+H) already does this, which is why I mentioned filling in the description for subVIs.
___________________
Try to take over the world!
Message 33 of 52
(1,974 Views)
Why someone rated one star this?!?!?!?? Smiley Mad  Let's try to repair... Smiley Happy
graziano
Message 34 of 52
(1,953 Views)
Yes, indeed. But it would be really helpful to have the same possibility for the description of all the components of a diagram.
Currently, the description field is not really useful. Does it make sense to write descriptions if it is so laborious to find and to read them ?
So once again, my dream :
  • The components with a description are highlighted on the diagram
  • The description is displayed when moving the mouse over a component
PS : I will join Graziano to correct your 1* rating...
Message 35 of 52
(1,946 Views)
This could be very annoying when wiring.
I think that is why NI has disabled the Tip at block diagram.
It will need a disable button, if implemented
Message Edited by Pnt on 07-15-2008 03:32 PM
Message 36 of 52
(1,934 Views)
Would it be more annoying than the context help ? What's about mouse over element + key combination to show the description ?
Message 37 of 52
(1,918 Views)
Mouse over + D will do there is no need for a disable button right?
Message 38 of 52
(1,913 Views)
Why someone rated one star this?!?!?!??   Let's try to repair...
graziano
That is me by mistake and am extremely sorry.
Message 39 of 52
(1,910 Views)
Okay,
   I think that now it's fixed!
graziano
Message 40 of 52
(1,882 Views)
