Flat sequence doesn't execute sequentially
All I know is this code below works perfectly fine for me.  Therefore, there must be something wrong in one of your VIs.  My other thought is that you have another reference floating around somewhere that is resetting it.
Message 11 of 22
(3,015 Views)
I wrote a program, maybe similar,  you can play with. It seems the button did change before the subvi finishes.
Thank you!
Message 12 of 22
(2,979 Views)
If you press cancel, you are changing the value of that button.
XLoop changes to zero because the subVI is called in the next iteration and quits immediately after writing the value property.
Message 13 of 22
(2,975 Views)
Thanks. Sorry, I mixed the mechinical latch action, if there possible to hold the button till the subVI finishes?
Message 14 of 22
(2,968 Views)
Holding a button is a user interaction. What do you want to happen code-wise if the button is held?
All this seems way to convoluted to solve a simple problem. What is the program actually supposed to do in the end?
Message 15 of 22
(2,966 Views)
I want the "Cancel' button not change back so quick and wait till the subvi finished cancellation.
Message 16 of 22
(2,962 Views)
But it only changes when the user clicks it.  And for the subVI to stop, the user much change the value to FALSE.  It is not your writing to the property node that is doing that.
Message 17 of 22
(2,956 Views)
Also note that the exit button gets read in parallel to the subVI execution, thus the loop in the caller will iterate once more (calling the subVI and resetting the XLoop caunter) to read the new value before exit actually takes place.
Why are your numerics orange? They should be integers, right?
Again, there are probably much better ways to do all this. Why so convoluted?
Message 18 of 22
(2,950 Views)
Could you change the program to a better way? When user click 'start', the loop in subvi runs and output xloop and yloop, when user click 'cancel' (can be the same or another button), the subvi finish calcellation, then the start button is back to default again.
Yes the numeric should be integers.
Message 19 of 22
(2,938 Views)
I don't understand why you even need a subVI? All this could be done in a very simple flat state machine. I assume this is a simplified demo of some more involved code. Can you explain what the purpose is?
Message 20 of 22
(2,921 Views)
