Flat surface fit on 3d graph
Hi
I'd like to find a flat surface fit on a circle that is rotated 3d. I'd like to then rotate it to see it in XY graph.
I was trying to use solve linear equation vi with
A*X+B*Y+C*Z+D=0
where X, Y and Z are columns with coords of data points.
so linear equation would be [X Y Z 1] as a matrix, and known vector as [0]. But linear equation that solve this is obviously A=0, B=0, C=0, D=0. So I can't really use this function.
Is there another way to do it?
What am I doing wrong?
(3,298 Views)
Accepted by topic author siadajpan
All right, I found a solution
Instead of making
A*X+B*Y+C*Z+D=0
I can make
A/D*X+B/D*Y+C/D*Z=-1
LV is giving me A/D, B/D, C/D values, then I can calculate D
(3,287 Views)
