Flatten To JSON Function
Hi all,
I need send JSON string via HTTP. I used Flatten To JSON Function but if I have input type: double (named resistance) and value e.g. 0.0035 function return this string: {"resistance":0.0035000000000000000729}   Why it is? How can I correct this to get string {"resistance":0.0035} ?
Thank you
(3,508 Views)
Welcome to a floating-point world where fractional numbers are stored as an approximation and not precisely.
0.0035 could be approximated as 0.0035000000000000000729 in the IEEE floating-point format.
https://en.wikipedia.org/wiki/Floating-point_error_mitigation
Santhosh
Soliton Technologies
(3,497 Views)
Understand. But do you have any idea how to do it to get string {"resistance":0.0035} ? 😞
(3,475 Views)
If you use JSONtext to do the conversion you will get 0.0035.  The inbuilt JSON functions are designed to preserve floating-point values, rather than decimal numbers that humans work with.
(3,456 Views)
Thank you. JSONtext works as I expected. 😉
(3,376 Views)
