Flatten / Unflatten to String: Losing Variant Data (Example Provided)
This is a simple one (I hope). When I take a cluster (which has a variant array as an element), I loose the variant data in the flatten/unflatten process. The simple panel and diagram are below. Where did the variant data go?
(3,447 Views)
Seems to work fine for me in LV 7.0.
Can you upload an actual VI?
___________________
Try to take over the world!
(3,420 Views)
I think I may have found the issue. The problem VI is attached ("test1.vi"). The variants in this example are actually Database Variants. If I use the database type information to convert these variants to a normal variant, then the flatten to/from string works properly.
Please see the attached "DB Variant to FlatString.vi" that fixes the problem.  I'm learning all the time - just very slowly!
(3,404 Views)
Yes, OLE variants are a problem. See here for some more examples. I think this may have been resolved in LV 8.x, but I'm not sure.
___________________
(3,393 Views)
