Flatten to XML doesn't work well with waveform attributes
I have an application where I have a data class containing waveforms acquired from DAQmx.  I'm using the "flatten to XML" and "write to XML file" to save the class object.  I get an error reading the class back in, in "unflatten from XML" I get error 1403 "Attempted to read flattened data of a LabVIEW class. The data is corrupt. LabVIEW could not interpret the data as any valid flattened LabVIEW class."
When I dig into the XML files, I see an entry for attributes, but it contains no data:
<Name>attributes</Name>
<Default>
<Name></Name>
</Default>
As a workaround, I'm able to strip out the attributes before I save the data. But I have to store the data somewhere else. Is there an easy way to save a class where all the data is preserved?
I've attached a example project in LV2013 SP1, run the "test class flatten and unflatten.vi". I get the error when I try to unflatten the waveform with the attribute, but not the one without.
-Jeff
(2,605 Views)
NO.  and lets look at the options:
  • TDMS: Does not support lvclass but, supports waveform attibutes
  • BIN file and datalog file:  generates error 4 on read
  • Scan to file: does not support lvclass does not mind waveform attributes
That throws out a whole lot of options.
That really only leaves a flattened string
(2,593 Views)
