Flex RIO
I am trying to set several channel properties on a PXIe 5764 digitizer card. However, I keep getting error -304404, with the error source text, "Attribute is undefined or not present in the currently running session".  The vi is attached and is modified from NI's example code, 'GettingStarted_5764-Basic.vi'. The code in question is contained in the disable structure.
Message 1 of 1
(2,617 Views)
