11-28-2024 12:13 AM
Hello everyone, I am using the Distributed Machine Condition Monitoring Example to learn labVIEW. This example requires FlexSignal Acquisition Reference Library 1.1.2 and Channel Monitor XControl 1.1, but the links provided for these two libraries are no longer valid. Can someone please send me a file for these two libraries? Thank you.
Solved! Go to Solution.
12-04-2024 09:25 AM
These are included in the downloads on that page (Distributed Machine Condition Monitoring Example - NI Community), Unzip the mcm_installers_part1.zip and you should find these files:
I've also attached the files in case you're having trouble downloading. Good luck on your LabVIEW journey!
