Float output from python
Hello everyone
I am using python node to output a float in a timed loop. The python output gets updated first time the loop runs but not after that. Whereas, if I try to output the corresponding integer value, the value gets updated on each call. I am using double data type in labview to accept the float value from python. Can anyone help me with this problem? I have attached the code below. The input is an array of shape (5,1) and output is a single float number.
Message 1 of 1
(1,981 Views)
