Float to HEX and back to float(bytewise)
@GeorgeLiu308 wrote:
Still no explanation for why you posted this code?  You don't need the loops at all.
Message 21 of 30
(1,466 Views)
... and you still did not notice that "boolean to 0,1" converts to I16, causing an up-conversion of all later data and the mentioned coercion dots. All this has been solved many times in the forum. Please only post if you think your code is significantly better. In that case you need to explain why. Just plastering an image without comments is pointless and not helpful. We don't even know if you offer it as a solution or if you require help because it does not work as you expect. Feel free to ask the moderator to remove your posts.
Message 22 of 30
(1,454 Views)
@omprakash wrote:
But do have any idea why im not getting required HEX(414F60C6)
instead im getting HEX( 417F67BB) while doing serial VISA read.
NOTE:char,integer and long are obtained correct.
If that is the data that is received, no conversion will fix it.
414F60C6 converts to 12.9611
417F67BB converts to 15.9628
If you're absolutely sure the device should send 414F60C6, then it seems to me there's a problem with the device. Or with your understanding of it.
Why do think 414F60C6 is required? What should this value be? Why can't it change? What is the device your reading?
If the device has a 'hold' button, that might only freeze the display, not it's internal value. So the display may show you 12.9611, that doesn't mean the returned value is 12.9611.
Message 23 of 30
(1,431 Views)
Hi Wiebe,
The message you are replying to is from the original poster from 11 years ago.  This is a zombie thread.
Message 24 of 30
(1,419 Views)
@RavensFan wrote:
Hi Wiebe,
Thanks.
Makes me wander why any of us responded...
Message 25 of 30
(1,411 Views)
No problem.
Most of the recent responses were a back and forth with a long time forum member, but first time poster who revived the thread with a diagram that he thought was "better".
Message 26 of 30
(1,404 Views)
@RavensFan wrote:
No problem.
I think those new posts came out of the blue.
AFAIK it wasn't the first time poster (there's no "author" icon), and the intent is totally unclear as well.
Message 27 of 30
(1,397 Views)
wiebe@CARYA wrote:
@RavensFan wrote:
No problem.
The resurrection of this thread was done by somebody who currently has a total of 2 posts, both of which are in this thread.
Message 28 of 30
(1,394 Views)
wiebe@CARYA wrote:
@RavensFan wrote:
No problem.
I didn't say he was the original poster  (now "author" based on the new icon that just got release in the past couple days.)  Just that his first posts were in this thread.  Even though he had registered on the forums a long time ago (back in 2015), thus a long time member.
Basically it made no sense for some who had been on the forums for 6 years to choose an 11 year old thread to post into for his first message with a "solution" that was not better and had no context as to why the thread should be revived after 11 years with his message.
I think we can now let this thread go back to Rest In Peace.
Message 29 of 30
(1,388 Views)
@RavensFan wrote:
wiebe@CARYA wrote:
@RavensFan wrote:
No problem.
Ah, OK. That makes sense.
Message 30 of 30
(1,380 Views)
