Floor (roundind toward -infinity) error
Hi everybody,
I just found a surprising error in Labview 2013. I want to get the interger part of the division of 2 float numbers: after the division I use the "floor" vi in the numerical palette. In some situations (with numbers below 1) this interger part is lower by 1 to what is should be. Example:
300m / 25m = 12.00 (division output)
floor(12.00) = 11.00
It seems to work only when both initial number are <1 and not in every configuration. I was wondering if it is some epsilon machine error in the calculation of the division
I'll use another solution for my calculation, but I think it may be corrected.
Regards.
(3,555 Views)
Hi Nico,
Yes.
For clarity: set the display format of your floats to "%.20g" to see the reason of this "unexpected result"!
You will find a lot of threads handling rounding issues with floating point numbers, here in the forum as well as on Wikipedia!
 Side note: why don't you use Quotient&Remainder function? It gives the same (flaky) result when used with DBLs…
(3,549 Views)
Didn't went that far in looking at decimals.
Quotient and remainder function has the same problem yes.
I'll try to dig the forums to find solutions, but I think the most obvious is to multiply both number by 10^n with n chosen so that the number I get are intergers (no decimal part). And then I'll use the quotient and remainder function.
(3,522 Views)
Hi Nico,
Yes.
You should. With floats: always…
(For background see IEEE754, IEEE854)
(3,516 Views)
Hum. Finally, I worked on mantissa and exponent, and added epsilon to division of the 2 mantissa. Seems to work without side effect. For the moment....
Many thanks for your help Gerd 🙂
(3,505 Views)
