Flow meter - configuration.
Hi ALL,
I am trying to read flow from Flow Meter (specification attached). K-factor = 24 Imp/l. = 0.0417 l/imp. So, I count edges inside the loop (time = 1000 ms) then multiply by 60 then multiply by 0.0417= l/min.
I have also attached modified example VI for my needs.
I don't know why I am reading flow 50 l higher then I am having on digital flow indicator.
Did anyone have the same issue?
gregorian7
(4,366 Views)
Hi gregorian,
I also use several KEM flowmeters, mostly the smaller ones…
And I read the flow basically the same way: reading a counter, getting the difference to previous value and scale by K factor.
I only recommend to do some averaging: with your current VI you will only get values with a step of 60*0.0417 l/min…
Well, when your VI runs fine (and IMHO it does) then this digital flow indicator might be configured wrong…
Did you set it's display range from 50 to 1000l/min as stated in your datasheet? Don't do this: the measurement range still is 0…1000l/min! (Zero pulses from flowmeter indicates zero flow instead of 50l/min flow)
(4,359 Views)
Thanks for you reply GerdW.
ZHM 07 KR.
I think, I am doing something. I am getting wrong readings. I've connected flow turbine in the circuit and read the same value that on the digital indicator.
I think my wires are fine. Ub+  to +15V PSU, SIngnal to counter and 0V to 0 on PSU.
Maybe I should read frequency rather then impulses.
gregeorian7
(4,335 Views)
Hi GerdW,
Could you give a clue how can I averaging the reading. As I read signal from 4 pressure transducers in the same loop and plot them in  XY Graph, the graph is not readable as flow is fluctuating a lot.
Many thanks,
Gregorian7
(4,299 Views)
