Fluke 43B Query Measurements - Harmonics
I'm having problems with the recent released driver for the FLUKE 43B Power quality analyzer.
For the data acquisition in the VOLTS/AMPS/HERTZ the acquisition is OK, however when I change to HARMONICS mode (in the block diagram), i don´t get the harmonics value. I would like to acquire THD data (the command for the fluke is QM 11 when in harmonics mode). Please could you help me to do this in an automated way?
The VI which I refer is attached.
Thanks!
(2,961 Views)
Hello Ren.Nak.
Is common when you change polymorfic VI selector, controls not change and nor wires broken. However, the VI not work. So, when you change the polymorfic VI selector, remember to delete control and create a new one. Attached is a visual explanation.
I hope have helped you.
Thanks for you contact.
Wesley Rocha
Wesley Rocha
Application Engineer
National Instruments Brazil
Visite a nossa comunidade em PORTUGUÊS!!!
Certified-LabVIEW-Associate-Dev
(2,744 Views)
