Fluke 45
The problem is that the things we see on our PC are different than the things we see on our Fluke 45.
B.v.:4 volt op de Fluke 45 display.
3 volt op de PC. ( Labview 5.1 )
Er wordt enkel de data van de Fluke 45 ingelezen via een GPIB bus.
Do you know what the problem is ?
Or do you know somebody who can know it ?
Do you maybe have some VI's, where you think it can work with !! ( it only most read the data from the Fluke 45 )
thanks in advance !!
(3,235 Views)
You can try using the simple gpib vi from the example
folder. You can enter gipb address and the write gpib
string(refer to instrument programming guide). You may also need to use an output format option.
Hope this help
guindon_jp@hotmail.com
(3,235 Views)
I would definitely check out the Fluke 45 driver available for download. It should be a great starting point for developing your application. Here is the URL: http://zone.ni.com/idnet97.nsf/9b2b33e1993d877786256436006ec498/d41b09d7a03a95c3862568ab005fbd3c?OpenDocument
(3,235 Views)
