Flush FIFO
Hi Guys,
sorry for the last dummy message.... seems today my fingers are working faster than my head does... 😉
Does anyone of you know, if there is a way to flush/reset a FIFO on an FPGA target? Doing dummy readings until it is empty is unfortunately no option 😞
Using LV FPGA 7.1 (still) and FIFOs located in BlockRAM. Read out in a SCTL Write (initialization) somewhere before ("normal code")
Have a nice weekend!
Cheers
Oli
(3,518 Views)
Hi Oliver,
unfortunately dummy readings to empty the FIFO are the only option on the FPGA. There is no special flush-methode available on this target.
Regards, Thomas.
National Instruments Technical Support
Message Edited by Tobel on 12-13-2005 07:38 AM
(3,492 Views)
