Flushing a LabVIEW SPI Script
Hi all,
I'm dealing with an NI 8452 and a SPI script.
I'm using the "SPI script" palette only because my protocol needs two Read/Write steps sequenced and the control of the delay beetween this two steps (in microseconds).
So far so good, it works nicely.
But I'm facing a problem : I can' find a way to flush the script.
The parameters of my Read/Write steps change from call to call, so I would like to make a classical model :
-static configuration once (clock, etc..)
-multiple calls of my Read/Write stuff with different and variable parameters
-closing the SPI Script reference once
The fact is it's not possible.
It's disturbing, because :
-some SPI Script VI " remains active until the script is complete or the setting is changed" (NI-845x SPI Script Num Bits Per Sample.vi), meaning the setting is overwritten if you recall the VI with the same SPI Script reference
- and some SPI Script VI just stack with the previous calls on the same SPI Script reference
The only way I find is to Create a SPI Script reference//Make my Read/Write sequence//Close the SPI Script reference each time I need to read or write a data.
Is there a way to flush the "internal stack" of a SPI Script reference ?
(3,024 Views)
Anybody here ?
(2,937 Views)
