Follow up: Find method for Excel
For those of you who are interested, the problem that I had with the
Excel "Find Method --
"Error 1004
Exception occured in Microsoft Excel, Find method of Range
class failed. Help Path is XLMAIN8.HLP and context 0 in "
-- is a common issue for the ActiveX "Find Method" and something that
Microsoft needs to fix. Their developer pages said that it is a bug
that occurs when the search item cannot be found and can be worked
around with good error handling. However, I get the same error when the
word that I'm searching for is present. I've got other solutions to my
problem, but they are so sloooow.
ej
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,115 Views)
I think this is what I need for my application. Can you please post up your VI? What I need is to search for a string and return me the row and column number if it's found. Thanks!
(3,092 Views)
Hi Pas123!
First off, it looks like EJ's post was made in 1999... so I'm thinking that you're probably not going to get a response from him 🙂
Secondly, you might find this link useful. It describes using the Excel Find method and also gives an example with VBA. Porting this functionality to LabVIEW is only a matter of figuring out how the ActiveX class is built.
http://www.dicks-blog.com/archives/2004/03/29/the-find-method/
Hope this helps, and good luck!
Travis H.
Travis H.
LabVIEW R&D
(3,076 Views)
