Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Fomula nodes using complex variables
Labview user1
Member
09-13-2007
05:01 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
My big equations are becoming very nested in Labview's math graphics. I noticed that Fomula Nodes don't take complex variables. Is there an easy work around for this type of situation?
Thank you,
John
0
Kudos
Message
1
of 3
(3,233 Views)
Reply
Re: Fomula nodes using complex variables
altenbach
Knight of NI
09-13-2007
05:12 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If you have newer version of LabVIEW, you can use a mathscript node. It supports complex numbers.
What kind of equations do you have? Many times the wire code can be dramatically simplified.
LabVIEW Champion
0
Kudos
Message
2
of 3
(3,230 Views)
Reply
Labview user1
Member
Author
09-13-2007
05:28 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I have Labview 8.5, so I'll give the mathscript a try. My equations envolve RF matrix transformations...no repetitive section.
Kudos
Message
3
of 3
(3,226 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
