Font change in text enum ring and display issue
I was finally able to update the text in a text ring programmatically, but for some reason, when I choose it as a drop-down menu, I just see blanks.  Also, for some reason, the font used is changed - it is more spread out and and block letters.  Any ideas why this is happening?  I am using the "strings[]" property from a property node to update the items in the list.
Jason
(3,213 Views)
Hi Jason,
Can you please post a simple VI that demonstrates this issue.
Ankita
(3,178 Views)
I did get it fixed - thanks much for the reply!
(3,171 Views)
