Font for customized menubar
I would like to change the size of my menubar in a VI.
I found that the system font in Labview is assuming that but as soon as I
created the exe file, the font came back to it's original size.
Then I tried with the Windows 98 menu font parameters. All menus in others
software changed but not the one in my EXE file from Labview!!!
Do you have any idea ?
Best regards.
Stéphane from France.
(3,048 Views)
The font is currently determined by the .ini file. When developing, you
are using a file called labview.ini probably. When running your EXE,
you do not have the font specified in your EXE.ini file, so LV uses a
default font. The easiest way is to copy your labview.ini file and
rename it to "myEXEname".ini where myEXEname is the name of your EXE.
Greg McKaskle
(3,048 Views)
That's perfect, thanks a lot.
(3,048 Views)
