Font size problem in executable
I changed the application font size from 15 to 14 in Options -> Environment -> Fonts. Now all text on both the block diagram and front panel uses this font size when using the application font.
Looks good.
When I build this into an executable, it reverts back to font size 15
Looks bad.
How can I avoid this?
When I press ctrl + 0 on the front panel (without selecting a control) it shows that the panel default has size 14
(1,639 Views)
Accepted by topic author Basjong53
Open LabVIEW.ini file (located near LabVIEW.exe in the same folder), search for appFont, dialogFont and systemFont, copy these strings into the ini file, associated with your application, that is.
(1,637 Views)
