Font size too small LabVIEW 2011
I am new to LabVIEW 2011.  I am running to a problem when I load LabVIEW all the font size seemed to be very small and I don't know how to make it bigger.  It is difficult to see when everything is small.  Please see attachment picture below.
I tried to repair LabVIEW 2011 and I even uninstalled and re-installed but the font still turned out to be small.
Please help.
thank you so much in advance.
Marlin12
(3,400 Views)
Accepted by topic author marlin12
What operating system? Have you changed any setting in the OS, like perhaps the default font size, or the DPI settings? Try deleting the labview.ini file and have LabVIEW re-create it from scratch (it will do this when you launch and it can't find it). You can also try adding these lines to the labview.ini file:
appFont="Tahoma" 13
systemFont="Tahoma" 13
dialogFont="Tahoma" 13
(3,392 Views)
Thank so much for the quick respond.
To answer your question, I am running Windows 7.
I did delete the ini file just like you said and it works.
Thank you again.
Marlin12
(3,387 Views)
