Font type of front panel.
Hi!
In the indicators of the front panel, I have used a type of font "letra.ttf" that is not common. I have made an executable and when installing it in a pc that doesn't contain this font type, the indicator appears with other type of font, no "letra.ttf".
How could I solve this problem, could I add this font type to the executable?
Greetings!
Garrigos.
(2,813 Views)
I suppose you could try to add the font file as a Support File in App Builder.  I imagine font files need to be in a particular place in the OS (C:\Windows\Fonts, perhaps?  I'm guessing here...).  So I guess you could build an installer and specify a custom destination for the font file to go in whatever place it's supposed to go on the hard drive.
Good luck,
-D
(2,805 Views)
Hi:
Yes, the font files in Windows are located in the C:\Windows\Fonts and yes, if you copy a font file to that dir the font gets registered in the OS so that the applications can use it.  I was unsure about it but I've just  done it, so just do it!
Robst
Message Edited by Robst on 02-11-2006 08:29 PM
Robst - CLD
Using LabVIEW since version 7.0
(2,801 Views)
