For Agilent LCR Meter (E4980), which DAQ can be used for pc interfacing?
hi, I have Agilent LCR Meter (E4980), I would like to interface with pc by using LabView program. My problem is how to use it and which DAQ card/system suitable for interfacing. Please advice. Thanks.
(2,997 Views)
My suggestion is that you do some research in Instrument Control. You certainly do no want to use a DAQ card for this. The Instrument Manual chapter 8 gives you your options for control. There is a LabVIEW driver located here.
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,989 Views)
And for heaven's sake, read the Agilent manual. It tells you all of your options for pc connectivity.
(2,986 Views)
