For Loop , While Loop Help
Hello, I having trouble trying to get this to work.  I just learned While and For Loops and I am trying to get three LEDs to cycle automatically.  So when #3 LED turns off, the #1 LED turns on.  How can this be done?  I was using timer intervals as followed:
1 LED - 0 - 3 seconds
2 LED - 3 - 6 seconds
3 LED - 4 - 10 seconds
Thanks.
Message 1 of 10
(5,394 Views)
Hello Dragoon70,
I am not completely sure that I understand your question.  Please see the attached VI and let me know if it is what you are looking for or not.  I think that at least it should be a good starting point for you.  Please feel free to let me know if you have any questions.
Cheers!
Message 2 of 10
(5,385 Views)
Upon further review, the attached method is simpler and more robust.  I apologize for thinking hard enough on the first pass.  As always, let me know if you have any questions.
Cheers!
Message 3 of 10
(5,378 Views)
By any chance could you save the .vi files under version 8.0?
Message 4 of 10
(5,372 Views)
Not a problem, here is the 8.0 version.  I only saved the Boolean2.vi as 8.0 as the first one doesnt really cut the mustard.
Cheers
Message 5 of 10
(5,369 Views)
Thank you very much.  This seems to answer my problem.  I never thought about using Shift Registers.
Message 6 of 10
(5,364 Views)
Not a problem.  Have a nice weekend.
Message 7 of 10
(5,358 Views)
So from 4-6 seconds, both #2 and #3 should be on. Is this correct?
Here's a simple solution.
Message 8 of 10
(5,349 Views)
does anybody have vi in 7.0 version.i also want to see the example..
Message 9 of 10
(5,331 Views)
Here's an animated image of my example.
Message Edited by altenbach on 03-15-2008 08:10 AM
Message 10 of 10
(5,321 Views)
