12-24-2010 01:05 AM
CDM 2.02.04 WHQL Certified directory and click Ok.12-24-2010 10:03 AM
What's a MIB520 and what does this installation problem have to do with LabVIEW or NI hardware?
12-24-2010 09:36 PM
It is crossbow installation board which is supported by LABVIEW!!
12-24-2010 10:13 PM
Yes, it is supported but the kb you are referring to is old, NI does not maintain the FTDI driver, nor does it make the crossbow board. If you have a current FTDI driver installed, the message during installation makes sense. I would recomend contacting crossbow to see if their product supports the latest release from FTDI. I would also suggest you provide more information than "The example later given is also not working". Details such as error codes and a link to the actual example would be part of the details.
