For Mike Porter: Read from Spreadsheet File.vi" function
On 2/17/03 you answered my question about reading and viewing a test done last week back into Labview. I can open the "Read from Spreadsheet File.VI" in Labview and read the file "data.txt" into the VI. The data comes back into the rows & cells on the VI screen but I don't know how to open the graph to see the data as curves. I can see about a 3 x 4 array of cells at a time and the correct data is there but I want to plot it. Do I need to create a new block diagram and VI? I apologize for the vagueness of my question - I'm new at Labview.
(2,958 Views)
Create a VI with a Waveform Graph on the front panel. On the block diagram, insert a Read From Spreadsheet File function. Connect the All Rows output to the Waveform Graph.
(2,958 Views)
