For a three input Compound Arithmetic XOR function, the output result is ((A XOR B) XOR C).
For a three input Compound Arithmetic XOR function, the output result is ((A XOR B) XOR C), which makes the result TRUE for A=B=C=TRUE. NI maintain this is correct operation, but the result is not an XOR of what is applied to the inputs. Can anyone confirm that this is correct operation?
(3,225 Views)
Hi
NI has right, this is a correct operation.
Luca
(3,225 Views)
