For loop iteration terminal should start other than 0
Hi Friends,
I got a simple doubt in For loop.
Like any other programming language (lets take example c)
for(j=0;j<10;j++)
where i can start j with 0 or else i can start with 1 and so on...
But in labview i couldnt see the option availble, by default it will start with 0 and run upto n-1
So, is there any other way to control this for loop iteration terminal...
Please let me know, that would be a gr8 help
Cheers,
Suneel.V
(2,748 Views)
Just add your constant to [i] for further processing.
Message Edited by altenbach on 06-30-2008 07:52 AM
(2,745 Views)
No, you cannot change the iteration terminal to start at anything other than 0. Instead, just use a shift register. You can initialize to whatever you want and then use the numeric and comparison functions inside the loop. It used to be that you had to use a while loop but now that the for loop has a conditional terminal, you can use the for loop.
(2,737 Views)
I just had one of those "Oh man, my code could have been so much simpler" moments
(2,724 Views)
