For loop to get average
Attached is my vi file and sub-folder contains library functions for A_D card.
Now the table can display only one column of values. I want to break them to a 2-D array.
1st row-> average values when line active button is high
2nd row -> average values when line active is high for the next time
I want to replace the table with 2-D array, as I want to save this as a matrix.
Below while loop is similar to my other counter in previous example.
Hope this helps you to understand what exactly I am trying to do.
Thanks and regards,
Ravi.
Message 21 of 28
(1,697 Views)
Hi
Thanks for all the replies. I guess I wasn't very explicit.
I have a data source which generates say 1000 points, which is a noisy spectrum.
and this data set is repeated say 100 times. I need to average each elemeent in the 1000
point array  so I end up with 1000 averaged points. I 'd like to display the spectrum after
each aqusiiton  and be  able to stop it if it is good enough.
In a a normal program this would be trivial
do j=1,100
    do i=1,1000
        new_signal(i)=old_signal(i)+new_signal(i)
    end do
end do
do i=1,1000
    new_signal(i)=new_signal(i)/100.
end do
Many thanks again for any suggestions
Rgds
Terence
Message 22 of 28
(1,798 Views)
Hello Terence,
in Labview you can do this too, but you need one for loop less: LV can add up arrays with indexing all elements.
So your program reduces to:
do i=1 to 100
 get 1000 datapoints
 add data to old data (yes, you can add one array to a 2nd)
 display data
od
For 'old_data' you don't need an indicator, use a shift register instead.
See the attached picture.
Message 23 of 28
(1,794 Views)
look at the vi attached. What I did is simply look for the falling edge s on line counter.
When line counter = true => add the average to a 1D array
When line counter =  false => do nothing
When line counter change from false to true (rising edge) => do nothing
When line counter change from true to false (falling edge) => add the 1D array to the
2D array and re initialise the 1D array to an empty array.
I hope it is what you wanted to do!  Smiley Wink
Dai
LV 7.1 - WIN XP - RT - FP
Message 24 of 28
(1,688 Views)
Thanks a lot. You have implemented such a complex logic in a simple way! It took more than 2 hrs for me to understand it!
Ravi.
Message 25 of 28
(1,681 Views)
Dear Gerd
Many many thnaks for your neet solution it works really well.
Rgds
Terence
Message 26 of 28
(1,769 Views)
Hi!
Was it so complicated? I thaught the comments where sufficient! Sorry!
Next time, I'll try to be even clearer. You should understand that in 2 min!
Dai
Message 27 of 28
(1,670 Views)
No, your comments were really good. It is only the logic in two loops were bit tricky.
ravi.
Message 28 of 28
(1,665 Views)
