Force CRIO to use TLS1.2
How do I force my CRIO-9034, 9040, and 9048 to only accept TLS 1.2 for SSH?
(881 Views)
Which LabVIEW version? Which SSH functions?
Rolf Kalbermatter  My Blog
(813 Views)
After some reading, it seems that TLS is only used with HTTPS for the CRIO.
I want to make the web-based configuration page and ALL HTTPS connections (webdav, etc.) to the crio to be forced to a minimum version of TLS1.2.
LabVIEW 2024 Q1
(788 Views)
I believe I've found a way to force CRIOs to a minimum of TLSv1.2
  1. Use PuTTy (I use PuTTYPortable requiring no install) to SSH into a CRIO (let's say CRIO-1 for example)
  2. Login using the admin account
  3. Open openssl.cnf: vi /etc/ssl/openssl.cnf
  4. Scroll to the bottom: Shift-G
  5. Insert a new line: Shift-O
  6. Add: MinProtocol = TLSv1.2
  7. Press Escape, then type ":wq" (no quotes) and press enter to save changes and exit
  8. Restart CRIO, should be good
I've checked that this works by doing this:
  1. Open a linux terminal on the same network with openssl installed (I used another CRIO, lets says CRIO-2)
  2. Try this command: openssl s_client -connect CRIO-1:443 -tls1
    • If this command terminates (i.e. the shell allows you to input another command), then TLS1 is disabled
  3. Try this command: openssl s_client -connect CRIO-1:443 -tls1_1
    • If this command terminates (i.e. the shell allows you to input another command), then TLS1.1 is disabled
  4. Success!
Can anyone verify please?
(766 Views)
