Force sensor measurement and continuously record with USB-6009
My Dear Friends:
I'm new guy using the labview and DAQ,and i'm quite interested on it,now on my hand there's only a USB-6009 DAQ instrument,and i want to use it to measure and record the data from a force sensor.
If there's anyone can provide an example or even a similar one for reference,that would be very thankful!
Lots of greetings.
(1,075 Views)
Hi Liu,
When you are new then you should take the Training resources.
And you should also examine all the example VIs/projects coming with LabVIEW and DAQmx!
The pick a simple example VI explaining how to read voltage signals with DAQmx…
(1,074 Views)
