Format Date Time string language
When I use Format Date Time to get the current date with full name of the month (%d-%B-%Y) I got result with month's name in German, do you know how to get it in English?
OS language is English, but location german...
Message 1 of 11
(4,758 Views)
set the location to UK...
LabVIEW respects your local regional settings, so it gives German month names. When you need to be independent from OS settings you could implement your own conversion from month number to name...
Message 2 of 11
(4,739 Views)
app will run on various machines in Switzerland, it's not an option....
Message 3 of 11
(4,730 Views)
So what do you want? That the shown text respects the local setting or that the text is in English? You can't have both!
Rolf Kalbermatter  My Blog
Message 4 of 11
(4,720 Views)
It's the only option.
It's simple: either live with the names given by the OS, or convert month number to your own name.
Why isn't that an option?
Message 5 of 11
(4,717 Views)
That I know, I wonder if there's an elegant way to do that 😉
Message 6 of 11
(4,703 Views)
That depends a bit on how you're going to use it.
If you (or the user) specify the formatting from a file, you'd have to search and replace the resulting string.
If you have a VI that takes a timestamp, and outputs a string, it can be a lot simpler. An enum could also be used...
Message 7 of 11
(4,692 Views)
Hi wiebe,
that Dutch "mei" is nice! 😄
Message 8 of 11
(4,657 Views)
like I've told changing it is trivial, but I was hoping that there's build in way to do it
Message 9 of 11
(4,637 Views)
Hi tcie,
The "built-in way" is to rely on the OS regional settings (either configured by the user or by the company admin).
When you want something different than the OS regional settings then you need to program it: you already got solutions…
Yes, even wiebe's example is trivial.
You can pimp it up by implementing configuration files and options for your users to change the language/localization of your software…
Message 10 of 11
(4,634 Views)
