Format into String - Too many format specifiers
I am developing a Labview application, which writes some measurements into an EDF-File. EDF means European Data Format. An EDF-File has two parts. An Header Part and a Data Part.
I found on this website "https://teuniz.net/edf_labview/index.html" a free and small collection of VI´s for EDF. I attached the small collection of VI´s to this post. These are a great starting point for developing my application.
I am using the "EDF-header.vi" from the "EDFrecorder Labview 2011" folder. My problem is that when I am running the unmodified EDF-header.vi I receive the following error message:
This error message occurs in the sequence 1 of the stacked sequence structure in this VI.
Can you please help me, why this error message occurs?
Thank you very much in advance.
Michael
Message 1 of 10
(4,148 Views)
Format specifiers in all cases are ok. Are you sure you did not modify the code accidentally?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 2 of 10
(4,136 Views)
Accepted by topic author Michael_1122
Your problem is in some hidden code in Frame 1. If you expand that frame to the right you will find that there's some code there that ultimately does nothing. Delete that code and it should work fine.
Message 3 of 10
(4,095 Views)
Good catch! It's a really ugly and Rube-Goldberg-ish code!
However, this hidden code does not produce any error with LV2017. Probably the compiler optimizer sweeps it away.
Furthermore, it seems the error should be another, since there is no format string connected here.
Paolo
Message 4 of 10
(4,088 Views)
I removed the hidden code and the error stopped happening. LV2020 SP1 32b.
Edit: weirdly enough, the given code ran with default values does produce an error in that version but not in 2017. Not saying I didn't believe you when you said it before, but yeah.
So what values are you giving it in 2017 that are producing an error? How can we replicate in 2017?
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 5 of 10
(4,076 Views)
Yes, it was surprising that this was the error - I found it by running in highlight execution mode in LV2019. I didn't understand why it gave that error and didn't really investigate further once I found that removing it removed the error.
I fully agree with the Rube-Goldberg aspect of the code. Given some time (that I don't have right now) I think that I could get that code down to a few postage stamps in size without the stacked sequence (I can see immediately that at least 8 of them could be easily combined - they have FOR loops indexed off of the same input).
Message 6 of 10
(4,067 Views)
Based on the first response I think that pincpanter was unable to replicate the error. It appears that something changed between 2017 and 2019 versions that caused this to throw this error.
Message 7 of 10
(4,060 Views)
Whoops, I read pincpanter's last response as if it was from the OP 😅
Redhawk
Message 8 of 10
(4,054 Views)
Hello Paolo,
hello johntrich1971,
hello Redhawk,
thank you all very much for your support. As you mentioned there is in fact some hidden code in frame 1. I am working with Labview 2019, this is possibly the reason why I was the only one who got that error.
After removing the useless code part in frame 1, it works fine.
Michael
Message 9 of 10
(4,020 Views)
It was useful in that it highlighted some really poor LabVIEW coding habits.  😄
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(3,962 Views)
