Format into String bug
Format into String function does not properly interpret format strings that mix precision (%.#) and significant digits (%_#) specifiers. For example,
%.2f\s%_2f will be interpreted correctly, however, using %_2f\s%.2f will format BOTH numbers into strings with 2 significant digits.
LV help does state that "you cannot use precision and significant digits together in a single percent code", however, we are talking about 2 % code instances here.
Certainly an circumventable problem but an inconvenience nonetheless.
Zador
(4,581 Views)
I agree, this looks like a bug. The result is not as expected.
(4,563 Views)
Play with it a bit and it gets even stranger. The first underscore in a format code appears to cause all subsequent periods in format codes to be interpretted as underscores.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,547 Views)
Yep,
I have filed a corrective action request to have this issue addressed.
Thank you!
JLS
Best,
JLS
Sixclear
(4,518 Views)
This was reported to R&D (# 3P7BIJSQ) for further investigation.  A possible workaround would be to use multiple Format Into String functions and concatenate the results.
Thanks for the feedback!
Travis H.
LabVIEW R&D
(4,329 Views)
