Format into string problem
Sorry for asking a similar question I asked before, but I really have a problem with a string format. Even though I have already taken a look at the string format table, I still don't really understand.
In my attachment, I want my header to be in the format like this
Date/time              Flow unit             Pressure unit
23.3.2012/23:19     [flow unit]            [pressure unit]
time  flow1  flow2  flow3  pressure1  pressure2  pressure3
It said there are too few format and contained unwired or bad terminal
Which symbol should I put in this case to make my header look like what I want?
(4,556 Views)
So instead of continue in the tread you already have, you made a new one. Not the best to do.
But I'll try to give you a hint:
So you are trying to insert 4 values, but you only specify 2 places to insert values ( the two %s ).
Where should LabVIEW insert the last two values ?
And do you want the enum numbers or the strings ?
You need to tell LabVIEW what it has to do with ALL the values.
Next your broken wire:
What do you what to use for selecting a case ?
(4,547 Views)
The broken wire is for plotting. I haven't finished that part yet. So should i put 4 %s to make it work?
(4,543 Views)
I want enumerator because i want to limit the user to have the units i only provided
(4,540 Views)
You still didn't answer the question.
Do you what the value (number ) or the string (text) of the enum ?
As what you have wired now, you can the text with a %s or the number with a %d.
Try it out.
(4,537 Views)
Oh sorry i want the string of the enum. Ok i'll try. Thanks
(4,533 Views)
