Format of the parallel port base address
Just wondering if someone could please help with what I'm sure is a simple question
I'm currently trying the control the first 3 bits of the parallel port using the Out Port sub vi.
Using the Labview examples and help I can see how to find the base address of the port. My LPT1 port is 378 like most.
However the parallel port I'm trying to control is a added in extra PCI card and looking in the Device Manager this is LPT3 with 2 an address ranges starting at CF00 and CE00 . I understand how the address range of starting at 0378 becomes 378 for the base address. But whatabout CF00 asnd 2 ranges? What do I need to put as the base address for the Out Port for CF00?
thanks in advance
Nick
(2,977 Views)
Well, if you have a base address of CE00, then you put a base address of CE00. Your numeric control/constant Display Format would obviously have to be set to hex display to do this. Otherwise, convert CE00 to decimal and enter that.
(2,974 Views)
Thanks for the super speedy reply! Much appreciated
(2,964 Views)
