Format
Hello Friends
                In what Format datas are stored in the Labview.Likewise Icon,Text format Etc.
Jayavel
Jayavel
Message 1 of 10
(5,812 Views)
Hi Javavel,
data is stored in exactly the format you have programmed in your data-write routines Smiley Wink
If that is not the answer to your question you should rephrase the question...
Message 2 of 10
(5,800 Views)
  Hello Friend
                    I need for example:In one vi i given the passwords and all where it  is stored in the system and what format that file will be stored in system.
Jayavel
Message 3 of 10
(5,789 Views)
Hi Javavel,
just look into the block diagram to see where the data gets stored and which format is used for saving Smiley Wink
Message 4 of 10
(5,780 Views)
Hello GerdW
                 I asked in VI Properties i gave the passwords and all.In that passwords where it is stored in the system and what file format it should be saved . I asked default national instruments passwords and all
Jayavel
Message 5 of 10
(5,767 Views)
Hi Javavel,
ok, you asked for the password that is used to protect the [blockdiagram of the] vi...
The "encryption" used for vi protection isn't made public by NI. It's their internal information.
I guess:
- the password isn't written anywhere on your computer
- the password may be embedded in the vi itself
- most probably NI only uses the password to generate a key and this key is probably written into the vi
(There surely is some little information in the context help of LabView!)
When the goal is to unprotect vi where the password is unknown: You are [most probably] out of luck.
Either you "crack" the vi by guessing the password or you might ask NI to unprotect the vi - if you can prove that it is your own vi (which in turn is throwing the questions "Why did you forget your password? and "Why is there no unprotected backup?")
Message 6 of 10
(5,764 Views)
Hello GerdW
              I didnt do that VI.One of my collegeue did that VI.But now he is expired.So now i m handling that one.So i have to unlock the code .How to unlock the code.Can u give ur suggestions to unlock.Thanks
Jayavel
Message 7 of 10
(5,750 Views)
Hi Jayavel,
did you read my last message? Is there anything more to add?
(Ok, except: try to contact your ex-collegue!)
Message 8 of 10
(5,726 Views)
Have a look at this very recent thread on the same subject.
Message 9 of 10
(5,721 Views)
jack001 wrote:
Hello GerdW
              I didn't do that VI. One of my colleague did that VI. But now he is expired. So now I m handling that one. So I have to unlock the code. How to unlock the code. Can u give ur suggestions to unlock. Thanks
GerdW wrote:
Hi Jayavel,
(Ok, except: try to contact your ex-colleague!)
If his ex-colleague expired like he said, he is going to have a hard time contacting him.  Maybe he can hold a seance.  Perhaps a Ouija board can divine what the password is.Smiley Very Happy
Message 10 of 10
(5,698 Views)
