Formats for graphs that can be use in Labview like jpg,bmp or etc.
here is the VI and the CSV. Sorry for the inconvenience.
Message 11 of 30
(1,427 Views)
You haven't specified the delimiter as a comma with the Read From Spreadsheet File. You also don't want to be continuously reading the same file over and over again. The data is not going to change so I don't understand the while loop.
Message 12 of 30
(1,423 Views)
i do not understand what you mean by the delimiter as a comma with the Read From Spreadsheet File. Can you explain to me as im new to labview? Thank You.
Message 13 of 30
(1,417 Views)
First, go to the help menu and select Show Context Help. Always turn this on. Then, move your mouse over the Read From Spreadsheet function. In the lower right is an optional input called 'delimiter'. Right click on it and select 'Create Constant'. Enter a comma into the constant you just created.
Message 14 of 30
(1,394 Views)
i followed your instruction already. but they show me partial of the waveform instead of the whole waveform. then went i add more comma, this error message appears-Analysis:  The width must meet: 0 < width < samples.
Message 15 of 30
(1,360 Views)
this is the waveform that we get. the jepg format n csv format
Message 16 of 30
(1,362 Views)
I took a look at the the csv file and I don't understand the format. The data is certainly not the 1D array and I'm not seeing it in a quick look ar the 2D array output. How did you create it? Do you have a description of it anywhere?
Message 17 of 30
(1,347 Views)
i got the waveform from the oscilloscope. its the only format that i can save.
Message 18 of 30
(1,341 Views)
But what was the process you used to save this? And did you look in the manual to see if there was a description?
Message 19 of 30
(1,337 Views)
That is the only format to save the file in excel. the rest are graphic format. what do you mean by process??
Message 20 of 30
(1,317 Views)
