Formatting Array to String challenge
Thanks to everyone for the suggestions.  Eventually I came up with this (but it took lots of tries):
OK, why the 7F: I really want an empty string as the delimiter; but if you feed it an empty string, it uses a space instead.  However if you feed it a 7F, it uses an empty string (gee, how obvious! 🙄).
Message 11 of 27
(2,649 Views)
Right after I posted that, I got another idea:
Message 12 of 27
(2,647 Views)
Interesting. Does that solve this old idea ???
(Sorry, I just got power back after a 25 hour outage (very high wind and devastating wildfires nearby, you've see the news 😞 ). Was hanging off laptop and cellphone hotspot, running almost out of juice).
Message 13 of 27
(2,630 Views)
Do these last two options have any advantage or are those just the RG solutions? It sounded like you're being serious about these and I don't see why not to use the initial solutions posted to the thread, which are certainly more readable and easy to understand.
___________________
Try to take over the world!
Message 14 of 27
(2,618 Views)
Yeah Christian,
how arer things going on in Venice Beach? Are you far enough away from the fire areas? I keep my fingers crossed that everything goes well for you.
We have around 0°C and snow-rainy wheather in Berlin, so it's quite the opposite of your situation.
Greets, Dave
Message 15 of 27
(2,597 Views)
I'm a simple man. 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 16 of 27
(2,593 Views)
Corrections:
  1. If you feed it an empty string, it uses a tab.  Apparently it's checking for a null string to decide whether something has been wired.
  2. If you feed it a 7F, it uses the 7F; it's just that the string indicator doesn't display the 7F's.
Message 17 of 27
(2,557 Views)
I don't know what "RG solution" means.
Message 18 of 27
(2,555 Views)
Short for this... 😄
Message 19 of 27
(2,548 Views)
@altenbach wrote:
@billko wrote:
I'd actually rather see how Rube-ish we can get it.  😉
challenge accepted....
Well, I suppose that's a nice try; but it doesn't hold a candle to some of the psychotic code that I've seen over the decades.
Message 20 of 27
(2,529 Views)
