Formatting data for writing to spreadsheet
i am programming some instruments to do automation, now i want to write the data of every instrument e.g values i am programming and the values i am reading back , i want to write all this data to excel sheet , what is required is heading( name of every instrument) should come to the 1st row, and data corresponding to every instrument should come below that instrument heading only.
i htried to do this but data is not coming as expected
below i am attaching the vi, i am attaching the whole project because there are lotsubvi's, please open the Main new vi in front end folder, it contains the code
Message 1 of 11
(3,068 Views)
Use TDMS file format It's a Lot better option.Read the attached links.This might help you.
https://www.ni.com/en/support/documentation/supplemental/07/tdms-file-format-internal-structure.html
Message 2 of 11
(3,041 Views)
Run the VI and let me know whether this helps you.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 11
(3,035 Views)
Thanks kasureloaded and Ranjeet singh for the reply,
Kasureloaded
i will study this TDMS format and will try to implement this in the program,
Ranjeet Singh
i am not getting what is ther location of the file that is getting formed
Message 4 of 11
(3,028 Views)
Ranjeet singh,
i got it i need to give path at template location.
Message 5 of 11
(3,025 Views)
The excel is not saved anywhere, you need to store it...It can be implented in another way.Just play with boolean at second last VIs used there
--Ranjeet
Message 6 of 11
(3,022 Views)
Do i need to add one ,more vi to save data to file i tried by changing those boolean values but nothing is happpening
Message 7 of 11
(3,012 Views)
That boolean will only change the excel window behavior.
What else you are looking for Ritu?
--Ranjeet
Message 8 of 11
(3,005 Views)
i want to save that file to a prticular location and i am not getting how to do thois
Message 9 of 11
(3,002 Views)
Then the problem is old data will be replaced with new one..this is what you want?
--Ranjeet
Message 10 of 11
(2,998 Views)
