Forming a two byte address
The attached VI says what is required.  This is part of a address generation in which a two byte address is to be generated as shown in the example.... tried different by splitting and combining bytes.
But unable to crack it. Any help is welcome !! ( I know the VI name looks odd but I just named it so for want of a better one 🙂
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(1,991 Views)
Accepted by topic author MogaRaghu
If the data is clean (e.g. you can guarantee that the first four bytes of the U16 are 0, here's all you need):
(It would be easy to join the two results back into a U16, of course)
(1,987 Views)
That was the exact one  I required !
I was searching for something on line of the Logical Shift inside the Boolean Palette but missed the data manipulation inside Numeric.
Thanks Champion !
Raghunathan
(1,932 Views)
