Formula Node cannot use "fabs"? Anyone can help me?
you can increase digits, and abs works fine.
Message 11 of 14
(714 Views)
@mahu wrote:
maybe with some code, "if else". Not elegant but functionally
What kind of answer is that???!!
Every single problem posted in the forum can be solved "maybe with some code"? I would actually go as far as claiming "definitely with some code". 😄
How would "if else" increase the precision of a computation? That simply makes no sense.
A good solution is always "elegant" and "functional" at the same time. If a solution is not elegant, it can be improved. If a solution is not functional, it should not be posted.
If you think you have a solution, you need to be much more specific!
Message 12 of 14
(711 Views)
It works! Thank you very much, I didn't know this before, thanks again.
Message 13 of 14
(691 Views)
Thank you for you suggestion, it works now.
Message 14 of 14
(690 Views)
