01-31-2007 05:15 PM
01-31-2007 07:09 PM
@Talo wrote:
Also when I introduce the same data to this formula, one times I obtain some values in the out and when I execute the subVI with the same data I obtain other values in the out. Said it diferently I obtain different out for the same data in.
UOffset depends on the last 100 values, so if the history is different, the output will be different.
Please attach your VI so we can test. What LabVIEW version do you have?
02-01-2007 04:44 AM
Thanks Altenbach,
I use the version 8.0 of LabView.
I attached the subVI which I have problem and ones examples of the data file that I use how the input. The first file "In1" don't give me usually problems, but the other two files give me different results each time that I execute it.
02-01-2007 06:18 AM - edited 02-01-2007 06:18 AM
Message Edited by GerdW on 02-01-2007 01:22 PM
02-01-2007 06:51 AM
02-01-2007 09:07 AM
02-01-2007 10:10 AM
02-01-2007 10:33 AM
