Formula Strings
I have a set of four simultaneous equations that describe the inverse kinematics of a robotic system. I'm trying to solve them using the nonlinear system solver. My problem so far is in expressing the formulae as strings. For example, I assume that if I have a constant squared that I use the square vi and then convert to a string instead of converting to a string and then appending "^2". Likewise with trigonometric functions. But if I want to use a trigonometric function on one of my variables, how do I actually write the function as a string? Can I just put in "atan2(x)" as a string? Where can I find the string equivalents of the basic functions one would use in a situation like this?
Thanks.  Robot Happy
(4,399 Views)
Do you use a formula node? Then try the help.
Wiebe.
(4,388 Views)
I'm confused. Are you trying to create a formula parser, or are you trying to understand what functions to use in LabVIEW to implement formulas that you already have?
(4,374 Views)
I was just trying to find out what functions to use. It's still not working though. What's the difference between the system solver and the system single solution? I only want one solution but what if there are others??? Robot surprised
(4,366 Views)
Hi Robotz,
Thanks for posting your issue,I have searched through our information and have found two pieces of which may help you to work out which is best for your application:
System solver:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/gmath/zero-llb/nd-nonlinear-system-...
This one has a random start point.
system single solution:
This one starts and a specified point, that is the only difference I can see.
Also have you heard of the ‘To Variant’ function in LabView which allows to code data from one form to another, here is some other useful links.
Flatten string:
 https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/variant-to-flattened-string.html
To Variant:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/to-variant.html
Variant to Data:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/variant-to-data.html
Hope this helps,
Jordan Power
(4,321 Views)
