Formula in LabVIEW
We have purchased LabVIEW 8.0 and currently working on a project based on LabVIEW. I have to write out the result from a formula calculation to a parallel port. The result of the formula is a 11 digit decimal number. I need to display the result in HEXADECIMAL format and write it to 3 16bit registers in an external board. But after executing the formula, I'm not able to convert the result to hex format.
I look forward to your reply at the earliest.
Yours faithfully,
Vishnu Rajendran,
JRF,
BCG,
CDAC Trivandrum.
(3,227 Views)
Check the numeric representation of the result of your calculation. If its a float it has no hex representation - at least in the sense that an integer does.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,220 Views)
If it does yield a float then you will need to typecast it to an unsigned integer in order to get it into the IEEE-754 spec. You can create an indicator for the unsigned integer, and as Mike indicated, this will have the option of displaying it in Hex on the front panel.
(3,208 Views)
