Formula node calculation error
Hi all,
I am expecting the output of formula node as the value of "c" input variable. but it outputs NaN.  I am attaching jpeg file illustrating that.
Clarification would be appreciated.
Kousy
Message 1 of 8
(4,718 Views)
Hi Kousy,
   first of all, I wouldn't rely so much on computations with "non-acutal-number" (I don't know how can I call -Inf, +Inf).
   Anyway, Inf/Inf = NaN, since you does not know which order is each Infinite, even if you have a zero multiplied at numerator.
   Of course, I refer to the "limit" algebra, because in math, it's nonsense to speak of (Inf/Inf) as division between numbers!
graziano
Message 2 of 8
(4,715 Views)
Hi Kousy,
In your attached jpg, you set the input "a" as -Inf. And in your formula, you calculate (x-a)*(d-c)/(b-a). So you get the output as NaN.
You might need to check the value for parameter a.
mchen
Message 3 of 8
(4,714 Views)
My attached vi clarifies my problem.
Inf is creating a confusion i know, may be I need to do some work around.
Kousy
Message 4 of 8
(4,688 Views)
On your front panel you say you're trying to interpolate values. Have you tried the built-in Threshold 1D Array and Interpolate 1D Array functions?
Message 5 of 8
(4,668 Views)
I have not used these Threshold 1D Array and Interpolate 1D Array functions. Ill try and let you know whether this solves my problem.
Message 6 of 8
(4,635 Views)
I can understand Threshold 1d array but not interpolate 1d array function.
still what iam trying to interpolate is..
attached vi explains..
Hope that helps.
can you attach an example for the above 2 functions?
Message 7 of 8
(4,617 Views)
Hi Kousy,
look at attached example...
Message 8 of 8
(4,614 Views)
