Formula node
Dear ,
I would like to use formula node to build a function that does the following:
y=16 + (x and1)*16 + log2[(x and1)*(2x-65535)+(65535-x)]
In Exel is quite straight forward as in the attachment.
any help how to translate it into Labview Formula node?
=16+MOD(C6;1)*16-LOG(65536-C6+MOD(C6;1)*(2*C6-65535);2)=16+MOD(C6;1)*16-LOG(65536-C6+MOD(C6;1)*(2*C6-65535);2)
(4,779 Views)
Hi malkowki,
Like this?
Is "AND 1" the same as "MOD 1"? (My Excel doesn't know about MOD()…)
(4,746 Views)
You can copy that almost directly to the formula node like this:
off-topic:
Gerd, die Excel-Funktion MOD(;) entspricht in der deutschen Version der Funktion REST(Zahl;Divisor)
(4,715 Views)
Accepted by topic author malkowki
I the mean time I have found the solution just using the formula expression table from :
https://www.ni.com/docs/en-US/bundle/labview/page/formula-node-and-expression-node-functions.html
Thanks for your answers
(4,694 Views)
Why would you do a "Mod 1"? That'd be the same as "Round towards -inf".
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,691 Views)
