Four pictures in one
Hello I'm trying to create a program that will make a 4image fit into a 1 a whole image.. I have seen one example but it only does 1 image the and then the 2nd image overlaps the other.. I tried making one and i got stuck on the process of combining them into 1 image.. I only manage to do the said example so far.. Any form of help is appreciated.. thx
ill post my work as soon as come back from work
(3,250 Views)
I'm not sure what modules you have available, but if you have all the vision stuff you could:
1) Convert 4 images to arrays (image2array)
2) Concatenate arrays in the correct locations
3) Convert new array back to an image (array2image)
(3,241 Views)
U can extract the images in one loop and feed the Data Image array in shift register.  Here an example:
Functions: Read PNG Image (I'm using some PNG icons in example), Unflatten PixMap (24 Bits), Flatten Pixmap and Draw flattened pixmap
(3,226 Views)
thx sir for the help would you mind posting your VI? Im still getting familiar with labview atm.. thx again
(3,163 Views)
